RCU Forums - View Single Post - Battery question
Old 02-23-2006 | 10:21 PM
Terror Dactyl's Avatar
Terror Dactyl
Default Battery question
I am curious as to what might be the solution to a problem I am having. I am running a std servo for throttle, three 5945, and an 8611 for flight controls.
The problem is the 2700/5cell nimh that I am using is a bear to charge as the Trition and Activator chargers that I have will trip out after anywhere from about 275mah to about 650mah at a time.
I got back with the vender that I got them from and checked if it is okay to go with a constant charge 500mah 9v wall wart. They said that will be fine just make sure that I monitor the temp and time.
I figure the guys with the really big birds that are using multiple packs and heavier draws than this, which begs the question how do you charge them when they are Nimh?????
