ORIGINAL: leercguy
Any suggestions on how to set up the elevators on my F-90. I currently have them connected to channel 2 & 5 with mixing set up on one of the optional mixing settings. I am using a Futaba 9 CAP and when I use the throttle cut the right elevator goes up. I'm not sure why this happens but there must be a better way to set this up. Any help will be appreciated.
If you have 8 channels:
What is the easiest way to do twin elevator servos?
Use the ailevator function, designed for just this purpose.
Plug servos into 2 and 8
Go to AILEVATOR
Make the function active
Test your elevator movement. If one is going the wrong direction, reverse the % for that servo (ie -100%).
IMPORTANT READ ME: Do you want your elevator servos to also act with your ailerons? If NOT, you must reset the AIL3 and AIL4 numbers to 0.
If you cannot use channel 8 for some reason, then you will want to use mix(es) instead.
http://www.futaba-rc.com/faq/faq-8u-q586.html
