RE: Torque rolling and hovering question?
Jabbing the throttle is another technique used by some guys that works.Throttling up and down like that gets the air blast over the ailerons to make them more effective. Torque rolls work better with the nose up almost vertical. You need more power with the nose higher so you get the air blast on the ails. Lots of ail. throw helps too.
