ORIGINAL: tccrab
I'm not real happy with the ailerons, I chose the one servo in the fuse option when I
built it and I'm beginning to think I may opt for the two servos in the wing option.
They seem a little sloppy, not as firm/crisp as I would like.
Tom, this is something you should deal with. On a high speed plane, slop can lead to flutter, which could end up tearing the ailerons apart. Check the aileron linkages for slop and make the necessary changes before you fly.
