ORIGINAL: BalsaBob
Regarding the nosewheel steering cable .......... Wondering what the best method/technique is of attaching the cables to the steering arm. Had planned on placing the cable through the hole and then looping it back around (and crimping a small piece of brass tubing to hold it). I am concerned that this small loop will rotate/kink as the strut retracts and then extends. Is there a better way ? Thanks. Bob
Bob,
I'll assume your using the kit supplied strut...
I put a dab of silicone sealer on the loop and let it dry in the "gear down" position. This keeps those little buggers in place and from kinking.
Dave "got 82 flights on mine" Rigotti
