RCU Forums - View Single Post - Engine stalls
Old 02-25-2006 | 03:54 PM
azzman's Avatar
azzman
Default RE: Engine stalls
Basically check to see if the carb is closing all the way when you apply the brakes, ther should be a gap of about 1mm or so there. If your idle is spot on then thats the same gap you should see when you apply the brakes, but if the idle screw is not adjusted properly it will close up.
The idle screw is like a stopper screw.
