RE: multi engine Which 1?>
Ok, let's get creative. I would agree that the twin fuse system and a large wing are really easy to fly and a lot of fun.
I have built a twin fuse KIND OF P-82 using two ugly sticks and loved it. I deliberately built the fuse's a bit far a part for better aerobatics, but closer would be more stable...Later converted it to a "500' stand off P-38".
I used two 60 size sticks and put 90's on it...Hey, the wing loading goes up some...my story and sticking to it.
Cedar Hobbies 60 size single engine stick is down to $85.00...x 2...$170.00. Took my around 20 hours to build it the first time. Aim for around 82" to keep the wing loading down and make the only new joint at the center. You can bolt the fuses to the wings using the original locations. Join the horizontal stabilizer. You can make the outer wing panels removable, but I used a brace to hold the fuse's in line for transportation. Does take a "Few" extensions.
twinman
