well, you just made Culverson's point
Not that it really matters, but it was MY point!!
But seriously, 14 bucks per gallon isn't that bad. I thought they were more than 20 per gallon...
If you buy at the LHS you will probably look at paying in the 20.00 range, but if you order direct and buy bulk then you can save a ton of money.
I order mine from Wildcat. they have a 5 case minimum for freight shipping. Try to go in on an order with others that fly. that is what i did, and it cut the cost way down. If you order by single case the UPS hazmat charges will make it wayyyy to expensive.
While I will ONLY fly Wildcat I'm am sure that any other fuel mfg will ship you via freight if the order is large enough. Best thing is to go in on an order with some friends. That way you can get a whole seasons fuel in one order and not have to worry about it all season long.
