RCU Forums - View Single Post - Outboard nitro engine trouble...
Old 02-25-2006 | 10:14 PM
Hobbes_KGB
Default Outboard nitro engine trouble...
Hi everyone. My grandfather recently endowed me with his old RC nitro boat. I've worked with nitro engines before but they were all brand new, and they weren't outboard boat engines. The problem is the whole thing is probably gunked up from sitting on a shelf for 20 years. I called HobbytownUSA and the guy there said to just soak the whole thing in nitro fuel overnight. I decided not to do that. I figured it wouldn't be good for all the parts that need to stay lubed on the engine, like the flex shaft and the prop. I decided to remove the upper engine section from the lower unit where the prop and the water inlet are. When I did this I discovered the flex shaft sticking out and noticed it was all greased up (this is when I decided not to soak it). I also noticed that when I tightened the bolts around the bearings that were now exposed, I could no longer turn the flywheel. So I loosened them until the flywheel was once again free to turn.
My questions are: What maintenence should I perform to get this thing back up to normal operating conditions? Should I soak any part of the engine in nitro fuel? Wouldn't that eat away at any grease or rubber tubing? Should I re-lube any parts of the engine, the carb? Should I be careful of any specific torque values for the bolts? Is the prop supposed to turn when I turn the flywheel in a clockwise direction? What if it doesn't? Should I just buy a new engine?
Thanks anyone that takes the time to read this. I hope to get this guy back in the water as soon as possible.
-Alex
