RE: Super Duellist 2/60 Build
OK got the cam out and a couple pics will tell the story on the length of the wing and the plan..
as you can see I moved the left wing tip rib out the width of it self ( 1/8" ) and then measured both wings from the tip to W1 along the main spar ... so as long as you are aware of the difference you can correct the length.
cheers
