RCU Forums - View Single Post - First idle up setup
Old 02-26-2006 | 11:47 AM
stimpey
Default First idle up setup
Hi all.
Till now., I have been setting up pitch for learning, ie -2 to 8, with the mechanics set up to give the usual 5 point liniar curve. ( hover at half stick at about 5.5 deg. )
having flown a 3D set up I now want to get more from my heli and want to copy the -9 to 9.
Here in lies my problem. If I set the mechanics of the collective to allow for this -9 to 9 it puts the normal flight mode way off. Is it acceptable to then set the normal flight mode with the first point on the pitch curve at about 30, and then liniar all the way to 100 to still give the same hover points etc, ie a reduced throw.
If I set the throw to limit the collective, I still end up with hover at over 3/4 stick.
In Idle up 1 its great. All liniar and hover point where it should be etc,
when I bring the collective all the way down, in normal flight mode, I end up with -8 and hover at over 3/4 stick.
How should I correct this?
Thanks.
