RCU Forums - View Single Post - Need ARF building advice please
Old 02-26-2006 | 08:49 PM
alienx
Default RE: Need ARF building advice please
Yea, the wing in almost anti-dyhedral if that makes any sense. It's perfectly flat , but with the flattish bottom surface, it almost looks like it bends down. It's just an illusion though. Anyway, you did give me one good idea. That is to try to see it the wingtips are level to the table. Then I can see if I need to work more on the wing, or try to shim the tail. I swear, no matter what two surfaces or pieces or acnhor points I try to look at, none are level to eachother!
I'm trying to be patient with this thing. I've already figured out that there probably isn't going to be the perfect model. And my desire to have a nice Cessna may have to wait a while. Maybe this model will end up being a sort of $70 Frankenstein of sorts! And then I can learn from it and buy a different Cessna down the road a little bit.
Thanks for taking a look!!!
