RCU Forums - View Single Post - Need ARF building advice please
Old 02-27-2006 | 05:42 AM
alienx
Default RE: Need ARF building advice please
ORIGINAL: balsabandit
Look closely at photo #2 It appears that the entire fuse is twisted. Looking at the firewall, it appears to have a clockwise twist, ant the empennage appears to have a counter clockwise twist. and obviously the wing saddle needs attention. Does the other aileron have the same problem, or is this just seen on the right side? The ailerons appear to be covered in some kind or semi-rigid plastic, so maybe remove them from the wing and try steaming them and inducing a twist until they are straight? I dunno, this is why I try to avoid all ARF's I had rather correct my own screw-ups than work on Joe Nguen's.
You are exactly correct (as far as I can tell). The airframe is glued inside the fuselage (all plastic), and it is either slightly off, or what I thought, there is a twist like you said. You are right about the ailerons too. They both have the same twist (maybe in opposite directions??).
I'm actually going to see if Wattage has any advice before I get too deep. I hate to have to keep correcting things every inch of the way. Bt then again maybe this is the best you can hope for!?
Thanks!
