RE: New WH 40% Extra in the works?
It is set up for 3 servos in each wing and 2 servos on each elevator. However with the new super powerful servos available we are hoping that we can reduce servo count to 2 in each wing and 1 on each elevator. We are testing the planes that way to verify that it all works together.
Reducing servo count to 2 and 1 reduces weight by at least a half pound and reduces cost by about $650 since you no longer need matchboxes.
It also has a tray for 3 servos on rudder, I think 3 will be required if you want the plane to perform at it's maximum capability.
TF
