9ZAP Programming problem
I'm playing around with the throttle cut/throttle trim to try and see the various ways to initiate start on my JetCat 120, currently using throttle trim with reduced steps. Problem I've got is that when yo go into the throttle cut screen you get the Active/inhibit line then the throttle rate line but I cannot get the throttle position set line to appear - can anyone shed any light on the problem, have I disabled something I shouldn't have ?? This function works fine on other models.
FAO Mick Burrell
Mick, you said that you initiate start using some mixes and the throttle cut function, coud you explain the mixes involved.
Nick (West Wales)
