RCU Forums - View Single Post - 9ZAP Programming problem
Old 12-04-2002 | 10:11 PM
mick15's Avatar
mick15
Default 9ZAP Programming problem
This is the way I do it
Goto FNC, go to throttle and disable the trim.
Goto CUT and enable, set to 100% select switch B set to "on off off".
You can now perform a learn RC acording to the ECU instructions.
To start the engine you move the switch to the centre position and go to full throttle. You will, of course have enabled the ECU for single channel operation.
If, as I do you require a throttle dual rate here's the next bit.
You follow this next part before the learn RC.
Goto PMX "3", activate and mark throttle as the SLAVE.
Goto NXT and set rate "A" to zero.
Return to PRO MIX 3 and select SWT select switch "B".
Perform the learn RC procedure, you can now set the RPM to say 100K. Goto AFR and throttle, you can now reduce the RPM by reducing the value of RATE "B",try say 60%.
When you are satisfied with the reduced RPM setting return to PROG MIX 3, goto SWT and set the switch position as "off off on".
The learn RC procedure is now repeated in the ECU,....done!
Your switch will now give you, medium RPM in the centre, high RPM down and stop, up.
BRG M
