RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 02-27-2006 | 01:21 PM
  #566
joe999
Default RE: Air Hogs Aero Ace!
ORIGINAL: bdavison
Bear in mind that the Aero Ace has a Lithium battery. Lithium's should not be charged at more than 1C or 1 times the capacity. Normally this takes a while...eg...the 30min wait times with the stock battery.
Yeap, I burned my plane doing that, but I thought it was because I left it too long charging - 20 minutes.
I did get about 6 flights using this modification and making sure to not charge it longer than 10 minutes. It sure was nice having the plane fully charged in under 10 minutes ready to go again.
Are there any fast chargers out there for this plane?
EDIT:
P.S. What about this one?
http://h1071118.hobbyshopnow.com/pro...?prod=EFLC3000
It says:
* For 3.7V or 7.4V batteries.
* Automatically detects between one and two cells
* LED light and beeper to indicate charging status
* Protects against reverse polarity
* Includes JST (BEC) plug and Mini-Tâ„¢ plug adapters
