RE: Whip aerials
Angus. I had similar problems when I put the servos in the tail of my Eclipse. I thought using long elevator cables wasn’t a problem with modern receivers but apparently it can be. I’m using a Graupner SMC19DS and with the elevator servo cables connected the range was reduced by approx 60%. I found out that adding a couple of ferrite rings eliminated the problem entirely (but added some annoying grams).
David
