RE: New Lanier Extra 330 87"
Progress report -
Hinged the tail surfaces and fitted the control horns. Elevator horns are the H9 type. Rudder uses the Dubro 913 setup (the black plastic arms will have to go - they are too big).
Also begun trial fitting the pull-pull setup. once I make the cables, I will move the servo tray to the right position on two beams epoxyed to the side ply. Servo will be the right 8611A and arm will be 4" (3" in the pircture).
