servo speeds
Hi Guys,
I would appreciate your advice. I have two JR 537 servos on seperate channels connected to my Ucando60 elevators. The left elevator is connected to the gear channel and the right to the elevator channel on the rx. I use a JR 2610 TX and when I raise my elevators the servos travel at different speeds. the servo connected to the gear channel is slower than the other.
I worked out how to increase the travel for the servos and they both travel as per the high or low settings to the required distance. however the servos dont get there at the same time.
everything is the same in regards to horns, the horn attachment &s the horns themselves. Is it a bad servo or is the fact using the gear channel the cause.
Any advice is greatly appreciated
