RCU Forums - View Single Post - Tip stalling Extra
Old 02-28-2006 | 08:40 AM
Flyfalcons's Avatar
Flyfalcons
Default RE: Tip stalling Extra
ORIGINAL: Serpant
Hi thanks for all your imput so far. I do fly it with the ailerons mixed with the elevators. I did think that was a good thing? If i put in more up elevator i get a downward movment is both aileron. Do you think that maybe making the problem worse. I set all my planes up like that.
Yes, that will DEFINITELY make the problem worse!! The ailerons are outboard on this plane. When they both go down, the wing tips are at a higher angle of attack than the root and it will tip-stall. Take out the mixing (this plane doesn't need it), line up the ailerons with the trailing edge as best as you can and give it another shot. This plane has a lot of potential, once you get this problem worked out you'll be a lot happier with it.
