RE: knocking Saito
This is an older engine, manual choke and all, and boy does it have compression. I never knew Saito made engines designed to run on 5% or less. Is there any way to tell if this is a high compression engine other than feel? Have you ran into many saitos with rod bearing knocking, if so out of courisity what does it sound like.
I appreciate all the help!!
Don
