RCU Forums - View Single Post - Balancer, How important??
Old 02-28-2006 | 01:33 PM
Red Scholefield
Banned
My Feedback: (9)
Default RE: Balancer, How important??
ORIGINAL: ffdq
Red: so no matter what kind of lipo,you must use a balancer.Also do you connect while you are charging or after charging.
thanks ffdq
Agreed, multicell lipo packs should be balanced.
Some balancing schemes work in conjuction with a Lipo charger, others work independenty as stand alone charger/balancers. Others will balance a pack by discharging each cell to the level of the lowest cell prior to charging, these will also limit the charge to each cell so that it does not exceed 4.2 volts. The balancing issue is addressed in a number of different ways. The simplest is to measure each cell voltage and then charge them individually. No balancer is required, only your regular lipo charger set for single cell charge.
