RE: OFNA Buggy help?
KX, only questions I had regarding that list is the starter box.... I couldn't find anything called "Chrome top...." but I was able to find a few that ran off 12v rather than the stick packs. Pretty much any box that works with 1:8 Buggies and runs off 12v is pretty much all that's important there, right?
Also, you spec out a Ofna clutch bell on that list. Is the one that comes with the kit not acceptable? Or perhaps the wrong tooth count? If so, is there anyway I can get a direct Tower link to the one you suggest I should use? Thanks man.
Edit: Also, I see you spec out an exhaust setup to go with the OS. Is this because the one with the kit is not a good one, or does the kit simply not even come with one? (See above, this was a question earlier in the thread).
