RE: Scratchbuilding F15 E
Problems to be solwed!
Well, the scale is 1:6.6(odd size?), But I have been calculating back and forth but From the drawings I have the model will bee 5 mm to wide compare to the technical spec I have over the F15, so I have to when doing the wings calculate and adjust he width by 2½ mm on each wing, I found this a bit disapionting, but guess it really doesn´t matter! If I in the end gets the right size of here! Or I can probably make the fuselage slithy shorter...
Any ideas how to do or just leave it?
And now to the next question!
How far distans between the frames can have?
The frames now are spaced 75-180 mm, I belive that the nose of the craft can be some distance(front of cockpit) to about up to 75 mm, but the rest? Areas round enginge are tight and also where the wings are, are there some recomends?
// Runar
