RCU Forums - View Single Post - BME Extreme 110 Carb settings?
Old 02-28-2006 | 11:01 PM
DKjens's Avatar
DKjens
My Feedback: (50)
Default RE: BME Extreme 110 Carb settings?
Brian,
These gas engines will often not act very linear with the amount of throttle given. It is different from engine to engine and from engine/airplane/prop/exhaust combination to combination. If your engine doesn't seem to increawe very much in power from 1/2 to 1/1 throttle, it may just be your combination. I most often use a throttle curve for my engines (150cc and up), where 1/2 on the stick yelds 1/3 throttle opening. As you said, you very rarely use 1/1 throttle, so broadening the area you do use on your stick makes flying much nicer.
DKjens
