RE: official smartech buggy thread
The knuckles (11413) are what I ordered, and they will not work without modifying. It looks lke they were made for 2wd. Even the pic shows the proper knuckles. I emailed them about this problem, and about the clutch.
Also, if someone can look at parts 11257 and 11258: I think they are supposed to be the same gears (pinion bevel gear), but the pic in 11257 shows an extra 'part' of the gear in behind the bevel. All I need is the gear, not the axle, but would I be taking a chance in ordering just the gears? Or better yet, has someone ordered the 11257 and found the gears to be correct?
Also, Banx, do you have a link to the hpi clutch in an online store? Does it have the two gear clutch bell as well?
Thanks!
Mark
