9C radio and servo set up
I have a 9C radio and understand about geometry and resolution on a servo pretty well I think. But for starters, the 9C has all default end points set at 100% which looks like it gives my servos about a 45* swing. Should I drive my end points to 140% to start, then set my high rates say for the elevator, so I get a 45* deflection with the geometry of the servo arm and elevator horn? Or should I back off on the end points to a lesser number then set my high rate throw with the arms?
