RCU Forums - View Single Post - Pull Pull Geometry problem
Old 03-01-2006 | 06:31 PM
Tricktrack
Default Pull Pull Geometry problem
I am having problems with my pull pull set up. I have measured and Re-measured several times to make sure everything is where it should be.
When I move the rudder one way the wires stay nearly the same tension. When I move it the other way, they loose their tension. Any suggestions as to what might be causing it to be completely fine one way and not the other.
