RCU Forums - View Single Post - Pull Pull Geometry problem
Old 03-01-2006 | 07:15 PM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: Pull Pull Geometry problem
The distance between the wires at the servo horn should be the same measurement as the distance between them at the control horn.
Find the distance between the wires at the servo horn. Make it the same on the control horn.
Did you cut the holes in the fuse to the same distance? The holes in the fuse where the wires exit need to be spaced at the same width as the horns.
