RE: 9C radio and servo set up
Most servos give you a 60* travel. Set your control surfaces up to give the recomended travel using100% as your default. Do this by varying the distance from the clevis to the hinge point. Then you can us the ATV option on your radio to fine tune travel.
As Bruce88123 mentioned, the further your servo wheel travels from center the less linear travel you produce.
