RCU Forums - View Single Post - 4 stroke engine problems
Old 03-01-2006 | 09:21 PM
TimC's Avatar
TimC
Default RE: 4 stroke engine problems
Yes low@slow, from what I've learned here at RCU, an air-bleed carb can be a bear when the engine is inverted. I've never tried it though. rctrax, that is a very good tip about grinding a servo wheel into an eccentric to operate a micro-switch. How did you grind it?
