RE: roto start/ tiger drive for .18 motor (truck)?
i have a tiger drive on my genesis and will never buy another one.....cheap plastic tabs with bolt holes on the cover are broke..the gears are half stripped,and the thing is desinged so that the part that ya put the shaft into has to turn to the right...that is opisite the direction of the roto start....not that big a deal if your using a drill..but i wanted to use my roto start unit with the t-drive shaft as not to have to haul yet another piece of equipment in the tool box not to mention batteries to keep up on...i tried to reverse the wires on a couple battery packs but remembering witch was witch was another pain i dont want to worry about...ill stick with the roto start
