RE: 4 stroke engine problems
Cambo, what I did was change to a female Universal type end for charging the sub C cells with my Hobbico Elite. I see from looking at my system that I left the 800 mAh sub C in the glow starter and paralleled another 2000 mAh battery to this one. If I had it to do again, I would go with the simple Y harness from the throttle channel on my receiver to another servo/ micro-switch like rctrax described. You could use your glow lighter charger to charge the battery for your onboard glow if you bought the right terminal. These are available with wires for remote glow uses. You really need to be able to solder; it's not hard at all. Cover the soldered joint with heat shrink tubing and your set.
