I just purchased AFPD and installed it on my desktop computer--which should meet the minimum specs, though it may not be optimal. Once I installed the program, I brought it up and it sits as the initialization screen and simply stops at the message "loading ChristianEagle plane." Never goes any further, then eventually it stops and Windows comes up with the usual "Do you want to send an error report to Microsoft" message. I'm not sure if its a video problem, sound problem, driver problem, compatibility problem, etc. My computer is a HP Pavillion a720n desktop computer with the following specs:
3200+ AMH Athlon CPU
512MBs of RAM
Integrated Graphics with 64MBs of RAM
After looking through the system, I discovered that the Graphics card uses the VIA/S3G driver. Their website is
http://www.s3graphics.com/en/index.jsp. I am running their Unichrome IGP card (DM400/KN400). Again, not optimum, but should work. From what I can gather, the driver does support OpenGL--in fact, it has OpenGL information under the Windows display driver info.
I also loaded this up on my laptop and it works great, so I know the AFPD cable works. My laptop has an integrated ATI Radeon X300 with 64MBs of memory and works beautifully. So I know the program works, but there seems to be some issue with my desktop--either hardware or software driver/compatibility issue.
Can somebody help please?
Thanks in advance,
Gerry Davis
