RE: Pull Pull Geometry problem
Well, you could make the servo arm parallel to the rudder control arm's current position ( you know / / ) to get the geometry more consistant if you wanted, but I wouldn't worry about it too much, unless it's real bad and you like to do a whole lot o tailslides, which is the only place you might have a problem.
