ORIGINAL: romanrc
The engine in the CUDA whe the plane is in inverted flat spin stop inmediatly, and I have more 40 dead stik landing. I have a friend is expert in walbro carbs, he put the needles just fine, the engine run great in the air and in land only in inverted flat spin stop in up ride flat spin the engine no stop. I use NX 23x8, amsoil and 87 octene gas. I put 6 holes in the fire wall of the Cuda and the engine stop.
I need to know if whit a internal trumpet the problem fix, but DA no answer to me and I do not know where I can buy one.
Mine also will run rich when inverted at 1/4 throttle or less. Great engine otherwise. Tweaked needles till I'm blue in the face. I tried a trumpet (velocity stack) on the carb. No difference..... [
