RCU Forums - View Single Post - Weedie 25cc ID ?
Old 03-03-2006 | 12:04 AM
KidEpoxy's Avatar
KidEpoxy
Default Weedie 25cc ID ?
new to converting, Saw a 25cc and was wondering if it was worth it:
Weedie B1750 Blower-Vac 25cc (not the low emit one)
from the parts manual: 530071456 Assy--Crankcase/Crank
1. the engine is used as a mostly vertical shaft orientation... does that matter? or just mount it right for prop use
2. What is a ballpark nitro size equivalent / prop suggestion
3. Is it worth it in a power to wt consideration
If it is just a generic weedie25, then I'll look up some more threads here to get up to speed on the conversions
thanx for any help ya'll can give
KE
