RE: Yak-54 Build and Q&A
Tom, Is the incidence on the elevator stabs 0 degree with respect to the fuse hatch (same as in your other planes) ?
Also it seems that the wing anti rotation dowels are kinda small (they sit flush against the fuselage when installed) & there is no place to drill the hole in them to install the cotter pin etc, as detailed in your manual/similar to other WH planes. Any suggestions ?
--Arvind
