RCU Forums - View Single Post - question for Ralph on your insulator !UPDATE!
Old 03-03-2006 | 02:00 AM
mikenlapaz
Default RE: I have a problem with my WA 167 carb....
I use that carb on a couple of engines. I found that there is sufficient protuding throttle shaft on opposite side of carb to slip on a wheel collar with a "sodered on" arm. Granted it requires modification for the pulse port alignment. I like a long arm on the throttle shaft.
