LOL
I assume that uses a second channel for the cut off? If so, if you have a 9 channel receiver or above, you can set aux 4 in device select to the mix switch and use channel 9 for the cut off. Otherwise you can set up a program mix, mixing the aux channel you wish to use to itself, assign the mix to the mix switch, and set the rates as needed.
