RE: 9C radio and servo set up
Ok thanks, now from what I have read, people are saying never run your ATV above 120% or below 80% and never run your low rates below 50%. Now that I think I have the high rate thing figured out, how would you not run your low rates below 80% or even 50% if your low rate surface deflection is only about a 3/8" deflection? I am dialing my dual rate all the way down to around 25% or 30% to get a small low rate deflection. Am I doing something wrong? At zero subtrim, and 120% ATV with the servo deflected to a 45* throw, the high end looks good, but I feel I am loosing too much resolution on the low end.
