RE: Jeti brushless controler not working. HELP
Try reversing the throttle channel. I believe that will fix your problem... To know if it will work first try and plug in the battery to the controller wile the throttle stick is at full. It sounds like it is going into the programing mode and that means that it thinks that it is at full throttle.
