RCU Forums - View Single Post - New H9 Cub??
Thread: New H9 Cub??
Old 03-03-2006 | 05:56 PM
  #96
bassman
Default RE: New H9 Cub??
Dave, you may have better luck with a Saito 72 than I will with the Saito 65. The 65 is actually larger than the 72. The firewall to prop hub lenght of the 72 is 4.095" while the 65 is 4.567" Do you really think a 52 four stroke will have the guts to fly this cub? If so I have a Magnum 61 or a 52 that I could use. It's good to know the landing gear works well. I just went thru the box and this has got to be the best ARF I've seen yet. THe assembled fuel tank, the precut radio foam and the overall construction look great. Any glue joint problems? If not then this is a real winner!
Bassman
