RE: Jeti brushless controler not working. HELP
Devin,
Thanks for your reply. You are partially correct. I have a computer radio and the end point throttle trim was off enough that the esp went into the program mode as you said. I found the problem by using another transmitter on that frequency and the esp worked, then I knew what the problem was so adjusted the end point of the throttle control and the motor started.
Was really frustrated for awhile.
Thanks again
Larry
