..other manufacturers have different recommendations, though......
I dug this summary out of the Superman fire thread from last year...
1 AMT is air start and will not auto start .
2 Simjet has a seperate ECU switch and would require both the ECU and Rec. to be left on.
3 Jet Cat uses a single switch but has a purge feature that is highly recomended.
4 Good comon sense practice of RX off before TX.
5 Use of external propane.
Up until now I have used external propane even though the Simjets I run are capable of on board gas. I was thinking of using the onboard but may just stay with external set up for ease of use and peace of mind.
Sure is nice to see what many people do to stay on the safe side in this hobby!
