RCU Forums - View Single Post - nemesis servo saver spring
Old 03-04-2006 | 11:20 PM
jombo's Avatar
jombo
Default RE: nemesis servo saver spring
i just checked my truck, the steering shaft just slightly rubs against the shock.well when i mean rubs it hits it but no major binding.check when you steer the truck see if it hits your shocks. also when you have the servo horn removed can you turn by hand your tires on the ground?
