PHCM wrote:
Not wanting to hijack your thread, but to compliment it.
Thank you .
The engine mount is aluminum along with the cage. I've decided to use the engine and cage from my last build. (the hull had issues)
G23 ?? is that a weedy or chainsaw? a weedy spins the opposite way that a chainsaw engine does, The advantage to using a chainsaw is that you can use tractor props with pusher set-up (giving a larger selection) . If you want a pusher with a weedy, you need to get pusher props. I like the pusher only because .....um..... uhh... I don't know why. I think it looks more "true to life"
I
think I might've gone a little wide on this build. The bottom is 20" the top is 28" which gives the sides a 35-40 (?) degree angle.
Didn't get very far today, I caught a bit of a nasty cold. You know, fever, cough... the whole bit.
