RE: nitro 4tec
Are there foam tire/wheel combo packages available online anywhere?
BTW, if you aren't already, use the shims that came with the car to adjust belt tension. They work. Mine were rediculously loose after todays bash session. So loose, in fact, all I had was rear wheel drive. They were slipping that badly. Added two shims and all is good again.
