RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 03-05-2006 | 11:48 PM
  #2449
Kiiski
Default RE: E-FLIGHT BLADE CP
Okay
Here is the newby question of the day. I was looking on the Thunder Power web site, thinking of ordering the TP1320-3SJ, specs are:
1320 mAh, 3 cells (11.1V), JST connector, 4-pin balancer connector
Rating: 13C (17A) continuous, 20C (27A) burst
Dimension: 34mm x 65mm x 19mm
Weight: 84gm
and the TP910-3S for when the day comes for doing some aerobatics, specs are:
910 mAh, 3 cells (11.1V), 4-pin balancer connector
Rating: 16C (14.5A) continuous,24C (22A) burst
Dimension: 34mm x 66mm x 15mm
Weight: 65 grams
The 1320 has both a JST connector and a 4-pin balancer.
The 910 has just a 4-pin balancer, and apparently no JST connector, and they don't seem to offer a TP910-3SJ.
2 questions, what is the purpose and use of the balancer, and, how do you connect the 910 that has no JST connector?
Kiiski
